Jail Upgrade from 11.1 to 12/13.x
pakka
Hi there,
I would like to upgrade my nextcloud jail, running on 11.1, to a higher version to get a newer PHP.
With command "iocage upgrade Wolke7 -r 12.2-RELEASE" I got an endless list of files to delete ("the following files will be removed as as part of updateing to..."). At the end I got "To install the downloaded upgrades, run /tmp/tmpwqlonbfy install" but nothing happens further and the command in tmp is not valid.
Is there a way to update? I tried also to update via UI, but it stays at 11.1
thanks a lot!
You can ignore the error about the tmp file.
You do need to complete the upgrade process by quitting (pressing Q) a few times after a couple of the steps which show upgrade notes (and also agreeing to a few questions along the way).
