iocage jails upgrade to 13 fails
gt2416
I am running into an issue where I cannot upgrade my 12.2 jails to either 13 or 13.1. All the jails have the latest patch p15. This is the error I get
iocage upgrade -r 13.0-RELEASE cups
Looking up update.FreeBSD.org mirrors... 2 mirrors found.
Fetching metadata signature for 12.2-RELEASE from update2.freebsd.org... done.
Fetching metadata index... done.
Fetching 1 metadata files... failed.
Command: /tmp/tmpoes5xbr2 -b /mnt/Storage/iocage/jails/cups/root -d /mnt/Storage/iocage/jails/cups/root/var/db/freebsd-update/ -f /mnt/Storage/iocage/jails/cups/root/etc/freebsd-update.conf --not-running-from-cron --currently-running 12.2-RELEASE -r 13.0-RELEASE upgrade failed!
root@truenas[...rage/Backups/Applications/smdr-logger]#
Any help would be appreciated. I am on TrueNAS-13.0-U1
Redcoat
Did you run iocage fetch first and choose the release to download?
gt2416
Yep, I have downloaded 13.0 and 13.1
SlackerDude
I also experienced this issue. Still searching for a solution, and will share if I find one.
adrianwi
Not that it helps, but I've upgraded 7 jails successfully (from 12.2-p2 to 13.1) in the last week. I had to recreate 2 due to other issues, but generally speaking, it worked well.
