Jail templates disappeared after 9.10.2 update
runtime
As you can see in the screenshot, VBox and standard jail templates have disappeared after updating to FreeNAS 9.10.2. Warden still shows them as available though.
How can I fix this?
Jailer
Not strong, but bad
Jailer
Not strong, but bad
What about the 'standard' template?
The standard template is the default template. I assume you are seeing the plugin jail template because you still have your old jail template from an older install.
And why was VBox removed?
@jkh has explained this on the forum previously. It was a hack to begin with and it's too difficult, if not nearly impossible, to keep the kernal driver and vbox versions cooperating.
