Jonathan Rose
- Feb 1, 2015
Long story short: between needing to revert from snapshot, needing to use a previous boot version (accidently killed a python process, which apparently damaged the nginx hosting the WebGUI), and (re)applying updates I found myself with extra warden templates for the standard jail.
The feedback I have gotten so far is that deleting the warden templates will destroy my existing jails. Here is my beef/inquiry about this: when I run `warden template list` I get the following output:
Jail Templates:
standard - FreeBSD (amd64)
standard--x64 - FreeBSD (amd64)
Now, if I run `ls -l /mnt/vol2/jails` I see the following as part of my output:
drwxr-xr-x 5 root wheel 5 Jun 18 19:58 .warden-files-cache/
drwxr-xr-x 2 root wheel 2 Jun 24 00:32 .warden-template-pluginjail--x64-20150703100105/
drwxr-xr-x 17 root wheel 21 Jul 3 17:55 .warden-template-standard/
drwxr-xr-x 17 root wheel 21 Feb 16 22:09 .warden-template-standard--x64/
drwxr-xr-x 2 root wheel 2 Jun 24 00:56 .warden-template-standard--x64-20150703100106/
From the WebUI I can see the warden templates take up approximately 8GB of storage. My logic is that removing these templates will force me to redownload should I need to create NEW jails. However, the feedback I have is that deleting them will destroy EXISTING jails. Seeing as how there are only two jail templates being recognized (which is fine as far as I'm concerned) but there are four on the system, how can I safely do housekeeping without damaging my jails and/or system?
Jail Templates:
