Jail drive dies - unable to remove plugins/mount points
Alister
Link to Help post
http://forums.freenas.org/threads/d...lume-but-plugin-wont-delete.14258/#post-68197
I have/had a SD -> SATA Adapter as my jail drive - it disappeared from the BIOS
I could remove the ZFS single drive from volume manager but the mount points and the plugin installed in the Jail are still there - and I can delete them they error out as they don't have a Jail. (see link for error or contact me)
I've backed up the config and when I look at the back up it has the mount points in the back up so I'm assuming that if I did a reset/restore I'd have the same issue? I'm guess that the restore wouldn't sense check to see that the config was possible - i.e. the Jail actually exists
D
dlavigne
Guest
It's not clear if the other poster ever opened a ticket at support.freenas.org. Please search support.freenas.org. If a ticket exists, add a comment. Otherwise, please open a new ticket.
Alister
This should be fixed in 9.1.0-p1
