Hi All:
I have been working to put together a new FreeNAS server for about 2 months :) While I have had the server up and running, I have been having some nagging "issues" with the box that leaves me uncomfortable with the stability and hence reliability.
Today, I noticed that the IPMI 3.3VSB (Standby I presume?) sensor is in a "Low Critical" state; indeed, the voltage being put out is around 2.4V, which is definitely low. Based on the log, this started happening on 03/17. Here is the output of the ipmisensor tool
I have already replaced the PSU (due to a CAM read error I have been experiencing in another post I am still working on).
I have this issue with both the Seasonic 760 Platinum and now an eVGA P2 850. So, I am going to go out on the edge and say that the PSU is probably not the source of my problem.
Any thoughts on this one? I have rebooted the server, but I have not yet reset the IPMI; would that be the next diagnostic step to take or perhaps upgrade the BIOS? Below are the particulars; note I have removed the identifiable information.
Thanks in advance for your assistance and input.
-Dan
jupiter# ipmitool sensor | grep VSB 5VSB | 5.000 | Volts | ok | 4.246 | 4.376 | 4.480| 5.390 | 5.546 | 5.598 3.3VSB | 2.432 | Volts | nr | 2.789 | 2.891 | 2.959| 3.554 | 3.656 | 3.690
Firmware Revision : 01.13 IP address : Firmware Build Time : 01/15/2016 BMC MAC address : BIOS Version : 1.0b System LAN1 MAC address : BIOS Build Time : 12/29/2015 System LAN2 MAC address :
-Dan
