Issues running duplicati on 13.1-RELEASE-p9
LoggSar
Hi there
I´ve installed successfully the Core-Version 13.0-U6.1
After this I installed syncthing (everything is working) and duplicati.
Trying to open the mangement-interface leads to an error.
So I looked at the jail, and there are some things I dont understand.
First of all - the jail is up and running
iocage list
| JID | NAME | STATE | RELEASE | IP4 |
| 20 | duplicati | up | 13.1-RELEASE | 172.16.0.10 |
| 11 | syncthing | up | 13.2-RELEASE | 172.16.0.2 |
So I logged in the cage (iocage console duplicati) and
/usr/local/etc/rc.d/duplicati status
duplicati is not running.
root@duplicati:~ # /usr/local/etc/rc.d/duplicati start
Starting duplicati.
So I tried to find out why and went to /var/log
tail mount.today
zfs_raid/iocage/jails/duplicati/root / zfs rw,noatime,nfsv4acls 0 0
This is also the output of the mount-command. However - I also added two more shares via the truenas-interface.
They are in /mnt - but not shown by the mount-command. Is this ok so?
Allmost all other logs only shows logfile first created
So - how to figure out why duplicati isnt starting?
Is there another log-file/directory?
What have I done wrong?
Thanks
LoggSar
Nordlicht-13
The Duplicati Plugin is not up to date any more. It comes with an old mono.
I'm trying to set up a new jail with duplicati as shown here:
It's not starting and stopping as it should be and I'm trying to get it running like the plugin used to work.
Nordlicht-13
Great, on my TrueNAS I can't get Duplicati to run anymore.
The Service can get started with "service duplicati start"
but I can't open Duplicati on 192.168.xxx.xxx:8200
When I check after that "service duplicati status" it tells me that it's not running.
Patrick M. Hausen
So it does not start. Investigate its logfile. Should be somwhere under /var/log.
Also you can try to run sh -x /usr/local/etc/rc.d/duplicati start, examine the last couple of lines of output for how the service is started, then use that command in an isolated fashion to gain more information.
Nordlicht-13
No, it starts
root@Duplicati:/var/log # service duplicati status
root@Duplicati:/var/log # service duplicati start
Starting duplicati.
duplicati is running as pid 8393.
Then I enter 192.168.xxx.xxx:8200 in the browser, and the duplicati web interface is not accessible.
After that I check in the Shell of the Jail again and I get this:
Nordlicht-13
I usually use sockstat to check if services are running.
With socksat I don't see the PID of duplicati
Somehow duplicati-service get's killed.
Nordlicht-13
The Service is starting (no changes to the .../rc.d/duplicati, still with standard-PW) :
+ check_startmsgs
+ [ -n '' ]
+ return 0
+ echo 'Starting duplicati.'
Starting duplicati.
+ [ -n '' ]
+ _cd=''
+ _doit='/usr/sbin/daemon  -f -p /config/duplicati.pid /usr/local/bin/mono /usr/local/share/duplicati/Duplicati.Server.exe --webservice-port=8200 --webservice-password=duplicati --webservice-interface=any --server-datafolder=/config'
+ [ -n duplicati ]
+ _doit=$'su -m duplicati -c \'sh -c "/usr/sbin/daemon  -f -p /config/duplicati.pid /usr/local/bin/mono /usr/local/share/duplicati/Duplicati.Server.exe --webservice-port=8200 --webservice-password=duplicati --webservice-interface=any --server-datafolder=/config"\''
+ [ -n '' ]
+ [ -n '' ]
+ _doit=$' limits -C daemon  su -m duplicati -c \'sh -c "/usr/sbin/daemon  -f -p /config/duplicati.pid /usr/local/bin/mono /usr/local/share/duplicati/Duplicati.Server.exe --webservice-port=8200 --webservice-password=duplicati --webservice-interface=any --server-datafolder=/config"\''
+ _run_rc_doit $' limits -C daemon  su -m duplicati -c \'sh -c "/usr/sbin/daemon  -f -p /config/duplicati.pid /usr/local/bin/mono /usr/local/share/duplicati/Duplicati.Server.exe --webservice-port=8200 --webservice-password=duplicati --webservice-interface=any --server-datafolder=/config"\''
+ debug $'run_rc_command: doit:  limits -C daemon  su -m duplicati -c \'sh -c "/usr/sbin/daemon  -f -p /config/duplicati.pid /usr/local/bin/mono /usr/local/share/duplicati/Duplicati.Server.exe --webservice-port=8200 --webservice-password=duplicati --webservice-interface=any --server-datafolder=/config"\''
+ eval $' limits -C daemon  su -m duplicati -c \'sh -c "/usr/sbin/daemon  -f -p/config/duplicati.pid /usr/local/bin/mono /usr/local/share/duplicati/Duplicati.Server.exe --webservice-port=8200 --webservice-password=duplicati --webservice-interface=any --server-datafolder=/config"\''
+ limits -C daemon su -m duplicati -c 'sh -c "/usr/sbin/daemon  -f -p /config/duplicati.pid /usr/local/bin/mono /usr/local/share/duplicati/Duplicati.Server.exe--webservice-port=8200 --webservice-password=duplicati --webservice-interface=any --server-datafolder=/config"'
+ _return=0
+ [ 0 -ne 0 ]
+ return 0
+ _run_rc_postcmd
+ [ -n '' ]
+ return 0
+ [ -n '' ]
+ return 0
Nordlicht-13
Updating the Jail and after that
pkg install sqlite3 mono6.8-6.8.0.123_2
made it work again.
Guess I have to check out TrueNas Scale in the future.
