Hi all,
In the past (11.1), I had tricks to get things setup and working the way I needed. In 11.3, I've been having various issues and after lots of tweaks I've now landed on an odd issue I can't get past. The goal is to have AFP sharing individual user home directories and allowing them to be time machine targets. In 11.1, this required me defining something in SMB sharing (but ironically not enabling the service) and things have been working that way for a number of years. One thing that never made sense to me (but I left it alone because it worked) was the home directory FreeNAS reported for LDAP-based users differently than what is explicitly in LDAP.
FreeNAS 11.1 would show this for a user:
FreeNAS 11.3 instead shows this:
The differences being the path to the user's home directory is now identical to what's in LDAP and the shell field is missing. Personally, I prefer the former (who wants to type cd /mnt/Mirror01/TimeMachine01/home/LDAPHOSTNAME/username instead of just /home/username ?) and care less about the latter since none of these users get shell access anyway (but it does appear 'su - username' from a root shell does give them a shell which seems wrong). However, I couldn't get it to work because now the basedir regexp doesn't match in 11.3:
In trying to make things work, I removed /home which exists on the FreeNAS ROOT and symlinked it to the proper parent path /mnt/Mirror01/TimeMachine/home. This got me past the above error and let me login and things look OK ... until I try to use the share. Copying a file onto the share works, huzzah! Unfortunately, creating a directory on the same share results in in macOS despite it actually creating the directory - only I'm unable to access it. Apparently the directory permissions are being set to 000, despite /etc/local/afp.conf showing they should be 755 in the home share:
Since I was able to 'su - username' despite the lack of a valid shell in the user record, I was able to confirm the same behavior occurs on the command line using mkdir:
So this is where I'm stuck now. Can someone advise why the directory perm directive does not appear to be honored and causes this issue?
username:*:uid:gid:User Realname:/path/defined/in/smb/sharing/LDAPHOSTNAME-BEFORE-FIRST-DOT/username:/shell
username:*:uid:gid:User Realname:/path/defined/in/ldap/username:
Feb 21 15:34:45.715251 afpd[62947] {netatalk_conf.c:1187} (error:Default): readvolfile: user home "/home/username" doesn't match basedir regex "/mnt/Mirror01/TimeMachine01/home"In trying to make things work, I removed /home which exists on the FreeNAS ROOT and symlinked it to the proper parent path /mnt/Mirror01/TimeMachine/home. This got me past the above error and let me login and things look OK ... until I try to use the share. Copying a file onto the share works, huzzah! Unfortunately, creating a directory on the same share results in
An unexpected error occurred (error code -50).
[Homes]
basedir regex = /mnt/Mirror01/TimeMachine01/home
home name = home
time machine = yes
cnid dev = no
file perm = 744
directory perm = 755
umask = 022
veto files = .windows/.mac/
FreeNAS-TM01% umask 0022 FreeNAS-TM01% mkdir test FreeNAS-TM01% ls -dl test d---------+ 2 username wheel 2 Feb 21 16:17 test
