Issue with Plex Permissions
Jath
I am trying to re-setup my Plex server on TrueNAS 12 after I had some technical difficulties with it. After I set it up, I added a mount point being my data pool for my data. I have an SMB setting setup for this data pool also.
After the first scan, it seemed to work fine and Plex seemed to pick everything up properly. But now, it keeps saying that it is getting an access denied when attempting to scan the folders. If I chown -R plex:plex to the /media directory inside the Plex jail, it allows scanning and all to work but it revokes all access I had with my regular user for SMB. If I grant it back to the SMB user, it takes it away from plex:plex.
How do I find the equilibrium for the permissions, or specifically grant the JAIL user access to a data pool outside of the jail?
Thank you.
