Issue with ISCSI
mst
Experts,
Last night we had a power issue and looks like I lost ISCSI storage from freenas. I think something might be with connection. Any thoughts. Please let me know what info I should post please. I use FreeNAS-11.1-U6 that is connected to Cisco 4900 and I use 10GB uplink ports.
Thank you
drinking12many
A lot of times I lose the drive on the ESX side when I have power outage etc.
If the ISCSI service is running on freenas then you can try this on the ESX side to see if its ESX. This needs to be ran on the ESX box, I usually just start SSH, and esxi shell.
esxcfg-volume -l this will let you know if it sees it.
esxcfg-volume -M labelname will mount it.
mst
I see
[VMware vCenter - Alarm alarm.NetworkConnectivityLostAlarm] Lost network connectivity on virtual switch "vSwitch3". Physical NIC vmnic6 is down. Affected portgroups:"ISCSI4", "ISCSI3"
[VMware vCenter - Alarm alarm.NetworkRedundancyLostAlarm] Lost uplink redundancy on virtual switch "vSwitch3". Physical NIC vmnic7 is down. Affected portgroups:"ISCSI4"
looks like from ESX both uplinks goes down - any idea? I know this is probably the cause. Faulty card? Cables?
mst
From ESX I cannot ping FreeNas aggregate IP:
[root@vmhost6:~] ping 192.168.10.7 10GB CARD on ESX
PING 192.168.10.7 (192.168.10.7): 56 data bytes
64 bytes from 192.168.10.7: icmp_seq=0 ttl=64 time=0.027 ms
64 bytes from 192.168.10.7: icmp_seq=1 ttl=64 time=0.019 ms
--- 192.168.10.7 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 0.019/0.023/0.027 ms
[root@vmhost6:~] ping 192.168.10.6 10GB CARD on ESX
PING 192.168.10.6 (192.168.10.6): 56 data bytes
--- 192.168.10.6 ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss
[root@vmhost6:~] ping 192.168.10.9 FREENAS LINK AGG
PING 192.168.10.9 (192.168.10.9): 56 data bytes
I think connection is an issue here - any thoughts?
mst
I only wonder how am I restore LUNS on Freenas when I fix the issue with the connection
drinking12many
Are you using a switch or are these directly connected?
HoneyBadger
actually does care
Administrator
Check the lower layers of your network stack first - does the switch show the ports as being up? Does it show the MAC addresses of the FreeNAS network cards? Is FreeNAS running?
You may also need to direct the ping to go out of a specific interface from the ESXi side.
mst
ESX shows ports up:
vmnic6 0000:05:00.0 ixgbe Up Up 10000 Full a0:36:9f:14:64:a8 1500 Intel(R) Ethernet Controller X540-AT2
vmnic7 0000:05:00.1 ixgbe Up Up 10000 Full a0:36:9f:14:64:aa 1500 Intel(R) Ethernet Controller X540-AT2
mst
Freenas shows:
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=e407bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether a0:36:9f:14:66:cc
inet 192.168.10.9 netmask 0xffffff00 broadcast 192.168.10.255
media: Ethernet autoselect
status: no carrier
groups: lagg
laggproto loadbalance lagghash l2,l3,l4
laggport: ix0 flags=0<>
laggport: ix1 flags=0<>
mst
I connect FreeNAS with ESX directly using both 10Gb ports. I am attaching EX PATHS since I don't think this is right. I should them both have active 10GB when using ISCSI - correct?
drinking12many
You have to set your paths to in ESX to either round-robin or alua to get it to use both paths. It really only helps if they are super busy. You can also use a script and powercli to do this on all devices if you have a bunch. I used to use something like this at my last job it only sets it on drives over 100GB though as written.
Get-VMHost | Get-ScsiLun -LunType disk | Where {$_.MultipathPolicy -notlike "Fixed" -and $_.MultipathPolicy -notlike "Roundrobin"  }  | Where {$_.CapacityGB -ge 100} | Set-Scsilun -MultiPathPolicy RoundRobin
