I've recently upgraded one of the GPUs in my TrueNAS SCALE-22.12.0 box, however the new GPU does not appear to be isolated on boot.
Previously I had a Quadro P600 and a GTX 1650. I had the 1650 selected in System Settings -> Advanced -> Isolated GPU Device(s) and it functioned as expected. The Quadro P600 was available to applications like Jellyfin and the 1650 was reserved for VMs.
I've since swapped the GTX 1650 for an RTX 3060 however despite showing up under Isolated GPU Device(s) the RTX does not get isolated. VMs will fail to start if the card is attached as a device.
If I run nvidia-container-cli I can see both devices are included:
As a work around I can stop all the Apps, un-tick Enable GPU support under Apps -> Settings -> Advanced Settings start a VM with a GPU attached then re-tick this setting and restart the Apps.
When I do this I see only the one GPU in the output of nvidia-container-cli:
I have to do this every time my NAS restarts.
I've tried clearing and resetting the Isolated GPU Device(s) list however it doesn't seem to help.
Another symptom I've noticed is I can't just select the GPU when I edit the VM, I need to manually add both PCI devices (the card and audio output) manually under devices. However when I do this it does work.
Any help appreciated.
Thanks.
# nvidia-container-cli info NVRM version: 515.65.01 CUDA version: 11.7 Device Index: 0 Device Minor: 0 Model: NVIDIA GeForce RTX 3060 Brand: GeForce GPU UUID: GPU-[UUID] Bus Location: 00000000:03:00.0 Architecture: 8.6 Device Index: 1 Device Minor: 1 Model: Quadro P600 Brand: Quadro GPU UUID: GPU-[UUID] Bus Location: 00000000:04:00.0 Architecture: 6.1
root@nas-01[~]# nvidia-container-cli info NVRM version: 515.65.01 CUDA version: 11.7 Device Index: 0 Device Minor: 1 Model: Quadro P600 Brand: Quadro GPU UUID: GPU-[UUID] Bus Location: 00000000:04:00.0 Architecture: 6.1
Thanks.
