I made a small iscsi share to experiment some and put some data on it. Can I change the size of the device to the full size of the array without loosing data? Or do I have to migrate it off then back on?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
