Hello
Since upgrading fro 8.2 b3 to final I see a whole lot of iSCSI errors such as these:
On the client side (Windows 2008 server) I get:
Obviously not good news. Used to work fine in beta 3 (although I have seen such errors in a few isolated cases) and haven not changed any setting (except, obviously, the upgrade itself).
Any idea / pointer most welcome !
(Freenas 8.2, Using iSCSI file extent, Windows server 2008R2 client)
Aug 21 01:28:07 freenas istgt[2249]: istgt_lu_disk.c:5209:istgt_lu_disk_queue_start: ***WARNING*** transfer abort CmdSN=42996 Aug 21 01:28:07 freenas istgt[2249]: istgt_lu.c:2865:luworker: ***WARNING*** LU1: lu_disk_queue_start() aborted Aug 21 01:28:43 freenas istgt[2249]: istgt_iscsi.c: 777:istgt_iscsi_write_pdu_internal: ***ERROR*** iscsi_write() failed (errno=32) Aug 21 01:28:43 freenas istgt[2249]: istgt_iscsi.c:3518:istgt_iscsi_task_response: ***ERROR*** iscsi_write_pdu() failed Aug 21 01:28:43 freenas istgt[2249]: istgt_iscsi.c:4967:sender: ***ERROR*** iscsi_task_response() failed on iqn.2011-03.example.org.istgt:freenas,t,0x0001(iqn.1991-05.com.microsoft:myserver.domain.local,i,0x400001370001) Aug 21 01:28:43 freenas istgt[2249]: istgt_iscsi.c: 777:istgt_iscsi_write_pdu_internal: ***ERROR*** iscsi_write() failed (errno=32) Aug 21 01:28:43 freenas istgt[2249]: istgt_iscsi.c:4984:sender: ***ERROR*** iscsi_write_pdu() failed on iqn.2011-03.example.org.istgt:freenas,t,0x0001(iqn.1991-05.com.microsoft:myserver.domain.local,i,0x400001370001) Aug 21 01:28:43 freenas istgt[2249]: Login from iqn.1991-05.com.microsoft:myserver.domain.local (172.16.100.5) on iqn.2011-03.example.org.istgt:freenas LU1 (172.16.100.10:3260,1), ISID=400001370001, TSIH=4, CID=1, HeaderDigest=off, DataDigest=off Aug 21 01:34:53 freenas istgt[2249]: Configuration refresh requested from 172.16.100.10
Log Name: System
Source: iScsiPrt
Date: 2012-08-23 02:00:58
Event ID: 43
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: myserver.domain.local
Description:
Target failed to respond in time for a login request.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="iScsiPrt" />
<EventID Qualifiers="49152">43</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-08-23T00:00:58.886418900Z" />
<EventRecordID>235257</EventRecordID>
<Channel>System</Channel>
<Computer>myserver.domain.local</Computer>
<Security />
</System>
<EventData>
<Data>\Device\RaidPort1</Data>
<Binary>0000010001000000000000002B0000C000000000000000000000000000000000000000000000000001</Binary>
</EventData>
</Event>Obviously not good news. Used to work fine in beta 3 (although I have seen such errors in a few isolated cases) and haven not changed any setting (except, obviously, the upgrade itself).
