CompuGlobalHyperMegaNet
- Sep 13, 2014
I was just creating a CIFS share of a dataset in which I store family pictures but I've noticed that when I select the Path, there are two locations in the drop down menu that do not appear as a dataset in the Storage tab. I then opened a shell via the WebGUI to double check the paths. These are the paths of the datasets and suspected folders.
Datasets:
Folders:
I should say that I passed the "I thought my data was gone but I just mounted a dataset over the top of it" right of passage years ago, so my theory is that the "folders" if they are folders, were created at some point when I mounted then into a Jail and used the Create directory option... that's just a theory though. There's part of me that thinks they're almost certainly folders and I could just delete them but as my "Pictures_and_Videos" dataset contains family pictures and videos, and as I'd rather avoid having to restore from and outdated backup (and reimport and edit the pictures from my DSLR / camcorder) I really don't want to take any risks without having as much information as I can get.
So here are my questions-
1. Is there any way of definitively ruling out the possibility that "dusan" and "Pictures_and_videos" are datasets?
2. Is there a way of differentiating between datasets and folders, be it on Windows, Linux or through the FreeNAS WebGUI or shell?
3. Should I just snapshot everything, delete the selected folders and check if the shit hits the fan?
Datasets:
/tank/Pictures_and_videos (note the lower case v) /tank/dozer_backup/dusan
Folders:
/tank/Pictures_and_Videos (note the upper case V) /tank/dusan
