SOLVED Is it possible to create a freebsd 10 / 11 jail in freenas ?
iXô
I would like to try doker within a jail, but it seems to need FreeBSD 10 or 11.
In fact I want to try what is described in the whats-new blog of 2015/07/docker-done-right.html
Is it possible to create a more updated jail than the host ?
Thanks.
D
dlavigne
Guest
Nope. You can install jail versions older than the host, but not newer.
iXô
I could, but this will not the most efficient way to acheive what I want.
I wanted to try FreeBSD 10 /11 for the new Docker stuff, that would permit me to deploy a small linux for providing xmpp gateway via spectrum2 that can't be build on freebsd.
I am hopping that Docker on FreeBSD is less resource intensive that virtualbox.
Thanks for the reply.
