i'm on freenas 11.1-u4 and was playing around with jails created via the gui while installing logitech media server. i had to try several times to install lms because i got errors, i wanted to try different options, or the install didn't run cleanly. i used the portmaster method and since i didn't know the best way to reset before a new build, i would delete the jail via the gui, and then create a new one. in doing so, i noticed some interesting behavior.
when i created the lms jail the first time via the gui, it took a while and i got the progress bar that showed the progress of the freebsd installation. when i ran jls in a shell, the jid i got for the lms jail was 2. i only have 1 other jail going for now. if i deleted the lms jail and created a new one with the same name, it would happen faster; no freebsd progress bar. jls would show the original lms jid+1.
when i settled on the recipe i wanted to install lms, i wanted to start really fresh. i deleted the lms jail and created a new one with a name i never used before. this time, it took longer and the freebsd progress bar came back. when i did jls, the jid for this brand new lms jail was back to 2.
is this expected behavior? when i was deleting and recreating a jail with the same name, was it really getting deleted? from the behavior i saw, it seems like freenas was reusing the old jail space of the same name. is it ok to reuse jail names? it seems safer to not to.
