- May 28, 2011
If after wiping the drives, you end up having the same issue, please do the following...
1) Rotate your SATA connections around so none of the drives are connected tot he same SATA data connection. Does the same problem exist, same hard drive being omitted (by serial number)? If you think you see a pattern to the failure, describe it.
2) Next why not post your system configuration and FreeNAS version, something we should have asked for earlier. Include things like the SATA interfaces if it's not just directly to the motherboard.
3) Post the output of "zfs list" and "zpool list".
I'm only trying to cover the bases.
