iocage upgrade on community plugin - Jail not found
FJoeAZ
I have 2 plugins/jails built on 11.2-p15 and as I am running TrueNAS-12.0 I thought I should update them.
But the when I use the GUI to update they both give the error: Major ABI change detected, please run 'upgrade' instead.
So I attempted to do an iocage upgrade from the HOST CLI and they both give the error: jail 'JAILNAME_####' not found!
Where JAILNAME is the jail name and #### is some random 4 alphanumeric characters that changes every time I attempt to run the command.
I have looked high and low for what might cause this issue or how the command thinks the jail is called something other that what it is actually called.
I have done updates before and successfully upgraded other plugins/jails but these two seem to have a issue that escapes me.
Any help or direction would be greatly appreciated.
What does iocage list show ?
FJoeAZ
It shows the same names as in the UI and the names I am using to run the commands.
To reiterate and be clear this is what happens:
# iocage upgrade jailname
snapshoting jailname_####
jail 'jailname_####' not found!
so you have a jail that's really called "jailname" ? or you just don't want us to know which jails you are using?
You should be using the command like this:
iocage upgrade -r 12.2-RELEASE jailname
Also, you may not be able to do a straight upgrade... 11.2 was dead a long time ago and those jails should be 11.3 for the upgrades to work properly, I think.
You may just be better installing the plugins fresh and copying over/using the config from the old ones.
FJoeAZ
No I am just using jailname as a alias as the name of the jail is not as important as the issue.
And yes I have tried that command to be clear all of these commands result in the same error:
iocage upgrade jailname -r 11.3-RELEASE
iocage upgrade jailname -r 11.4-RELEASE
iocage upgrade jailname -r 12.0-RELEASE
iocage upgrade jailname -r 12.1-RELEASE
iocage upgrade jailname -r 12.2-RELEASE
And I have fetched all of these releases in iocage in hopes that one might work.
If you think the actual plugin I am using would be of use I am happy to divulge but there is no info about this issue on the github repo for these community plugins with regards to the plugins I am using.
OK, so abandon it and go to my second suggestion then... it will be quicker anyway.
Just to be clear, your syntax isn't the same as mine... maybe try it my way?
FJoeAZ
Also I have successfully run an upgrade on 3 of my other jails. Just these 2 seem to have some sort of bug that is changing the jail name after the command is run.
FJoeAZ
But both the hostuuid and pluginname are defined in my config.json and correct so I guess that doesn't mater.
n0by
having the same issue with the nextcloud plugin for a couple of month (I think even before TrueNAS-12.0 upgrade). Nextcloud is on 11.3-RELEASE and I am not able to upgrade.
