I have a nextcloud jail instance that I am trying to upgrade from 12.3 base image to 13.1 base image, i get the following error.
Now the catch is that, when I ran the command for the very first time, I stopped it half-way by pressing
I have rolled back to a snapshot that I know it works well, and repeated the process however the error keeps coming up.
Q: Any ideas on where to check for anything corrupted that stop the upgrade from happening ?
The jail has been created against a 12.3 base image with no issues upgrading in the past.
Under the
This confirms the Jail is not a clone and makes use of 12.3 base image
Also if I try to run the
# uname -ro
FreeBSD 13.1-RELEASE
#iocage upgrade -r 13.1-RELEASE nextcloud
Mounting src into jail failed! Rolling back snapshot.
Ctrl-C
as I thought it had stuck. Apparently the upgrade was going on in the background. So I might have messed up with something but I cannot tell.I have rolled back to a snapshot that I know it works well, and repeated the process however the error keeps coming up.
root@freenas:/ # iocage list iocage list -l +-----+-----------------+------+-------+----------+------------------+-----------------------+-----+----------+----------+ | JID | NAME | BOOT | STATE | TYPE | RELEASE | IP4 | IP6 | TEMPLATE | BASEJAIL | +=====+=================+======+=======+==========+==================+=======================+=====+==========+==========+ | 39 | nextcloud | on | up | jail | 12.3-RELEASE-p5 | vnet0|192.168.1.55/24 | - | - | yes | +-----+-----------------+------+-------+----------+------------------+-----------------------+-----+----------+----------+
Under the
iocage/jails/nextcloud
folder the fstab
file reads likes thisCode:
# cat fstab /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/bin /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/bin nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/boot /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/boot nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/lib /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/lib nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/libexec /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/libexec nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/rescue /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/rescue nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/sbin /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/sbin nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/usr/bin /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/usr/bin nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/usr/include /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/usr/include nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/usr/lib /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/usr/lib nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/usr/libexec /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/usr/libexec nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/usr/sbin /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/usr/sbin nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/usr/share /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/usr/share nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/usr/libdata /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/usr/libdata nullfs ro 0 0 /mnt/MEDIA_VOL/iocage/releases/12.3-RELEASE/root/usr/lib32 /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/usr/lib32 nullfs ro 0 0 /mnt/RESILIENT_VOL/nextcloud/data/db /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/var/db/mysql nullfs rw 0 0 /mnt/RESILIENT_VOL/nextcloud/data/files /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/media nullfs rw 0 0 /mnt/RESILIENT_VOL/backup /mnt/MEDIA_VOL/iocage/jails/nextcloud/root/mnt/backup nullfs ro 0 0 # Added by iocage on 2020-11-21 10:54:25
# zfs list -t filesystem -o name,origin -r /mnt/MEDIA_VOL/iocage/jails NAME ORIGIN MEDIA_VOL/iocage/jails - MEDIA_VOL/iocage/jails/nextcloud - MEDIA_VOL/iocage/jails/nextcloud/root -
iocage upgrade
command straight after the error I get the following error, apparently caused by the snapshot.Code:
Snapshot already exists Traceback (most recent call last): File "/usr/local/bin/iocage", line 10, in <module> sys.exit(cli()) File "/usr/local/lib/python3.9/site-packages/click/core.py", line 1128, in __call__ return self.main(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/click/core.py", line 1053, in main rv = self.invoke(ctx) File "/usr/local/lib/python3.9/site-packages/click/core.py", line 1659, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "/usr/local/lib/python3.9/site-packages/click/core.py", line 1395, in invoke return ctx.invoke(self.callback, **ctx.params) File "/usr/local/lib/python3.9/site-packages/click/core.py", line 754, in invoke return __callback(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/iocage_cli/upgrade.py", line 40, in cli ioc.IOCage(jail=jail, skip_jails=skip_jails).upgrade(release) File "/usr/local/lib/python3.9/site-packages/iocage_lib/iocage.py", line 2086, in upgrade new_release = ioc_upgrade.IOCUpgrade( File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_upgrade.py", line 236, in upgrade_basejail self.__snapshot_jail__() File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_upgrade.py", line 403, in __snapshot_jail__ ioc.IOCage(jail=self.uuid, skip_jails=True, silent=True).snapshot(name) File "/usr/local/lib/python3.9/site-packages/iocage_lib/iocage.py", line 1719, in snapshot ioc_common.logit( File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py", line 107, in logit callback(content, exception) File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py", line 92, in callback raise callback_exception(message) iocage_lib.ioc_exceptions.Exists: Snapshot already exists
