IOCAGE FN11 RC3
Mark WatIng
Hi All,
Testing IOCAGE on FN 11 RC3, but does not work for me. Below is the error/screen output. Does anyone know what I should be doing to get IOCAGE working ....
I'm using FN 11RC3 under VMWare for testing purposes (using NAT).
Many Thanks,
root@freenas:/mnt/iocage/releases # iocage fetch --plugins ip4_addr="em0:192.168.160.131/24"
[0] BitTorrent Sync - Resilient, fast and scalable file sync software for enterprises and individuals. (btsync)
[1] CouchPotato - CouchPotato is an automatic NZB and torrent downloader. (couchpotato)
[2] Crashplan - Computer backup and data storage made simple. (crashplan)
[3] Deluge - Bittorrent client using Python, and libtorrent-rasterbar (deluge)
[4] Emby - Home media server built using mono and other open source technologies (emby)
[5] GitLab - Powerful features for modern software development (gitlab)
[6] Jenkins - Jenkins CI (jenkins)
[7] Jenkins (LTS) - Jenkins CI (Long Term Support Version) (jenkins-lts)
[8] MadSonic - Open-source web-based media streamer and jukebox. (madsonic)
[9] NextCloud - Access, share and protect your files, calendars, contacts, communication & more at home and in your enterprise. (nextcloud)
[10] Plex Media Server - The Plex media server system (plexmediaserver)
[11] Plex Media Server (PlexPass) - The Plex media server system (plexmediaserver-plexpass)
[12] Quasselcore - Quassel Core is a daemon/headless IRC client, part of Quassel, that supports 24/7 connectivity. Quassel Client can be attached to it to. (quasselcore)
[13] SickRage - Automatic Video Library Manager for TV Shows (sickrage)
[14] Sonarr - PVR for Usenet and BitTorrent users (sonarr)
[15] SubSonic - Open-source web-based media streamer and jukebox. (subsonic)
[16] Syncthing - Personal cloud sync (syncthing)
[17] Transmission - Fast and lightweight daemon BitTorrent client (transmission)
Which plugin do you want to create? (EXIT) 0
Plugin: btsync
  Using RELEASE: 11.0-RELEASE
  Post-install Artifact: https://github.com/freenas/iocage-plugin-btsync.git
  These pkgs will be installed:
	- net-p2p/btsync
Release 11.0-RELEASE missing, will attempt to fetch it.
Fetching: 11.0-RELEASE
Extracting: base.txz...
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fetch.py", line 893, in __fetch_plugin_props__
	with open(freebsd_version, "r") as r:
FileNotFoundError: [Errno 2] No such file or directory: '/mnt/iocage/releases/11.0-RELEASE/root/bin/freebsd-version'
  File "/usr/local/bin/iocage", line 10, in <module>
	sys.exit(cli())
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 722, in __call__
	return self.main(*args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 697, in main
	rv = self.invoke(ctx)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 1066, in invoke
	return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 895, in invoke
	return ctx.invoke(self.callback, **ctx.params)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 535, in invoke
	return callback(*args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/iocage/cli/fetch.py", line 114, in cli
	files=files).fetch_plugin_index(props)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fetch.py", line 1178, in fetch_plugin_index
	props, 0)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fetch.py", line 815, in fetch_plugin
	props, pkg = self.__fetch_plugin_props__(conf, props, num)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fetch.py", line 907, in __fetch_plugin_props__
	self.fetch_release()
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fetch.py", line 230, in fetch_release
	self.fetch_ftp_release(eol, _list=_list)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fetch.py", line 432, in fetch_ftp_release
	missing = self.__fetch_check__(ftp_list, ftp=True)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fetch.py", line 559, in __fetch_check__
	self.fetch_extract(f)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_fetch.py", line 685, in fetch_extract
	}, libzfs.DatasetType.FILESYSTEM, 0, True)
  File "libzfs.pyx", line 1775, in libzfs.ZFSPool.create (libzfs.c:38817)
TypeError: create() takes at most 4 positional arguments (5 given)
Mark WatIng
Glad it's not just me !
Sent from my iPad using Tapatalk Pro
Stux
I don't see RC4 either. If it was out, it must've gotten pulled.
scrappy
It's out today. Just upgraded to FN11-RC4 a few hours ago. Had the same issues as the OP. Trying iocage again as I type this.
Edit: I was successful this time in creating a jail using iocage.
