iocage-ix-plugins no longer working
Bernard Mentink
I get the following error on install:
iocage fetch --plugins --name "plexmediaserver-plexpass" ip4_addr="vnet0|192.168.178.203/24" allow_raw_sockets="1" vnet="on"
Plugin: Plex
  Using RELEASE: 11.1-RELEASE
  Post-install Artifact: https://github.com/freenas/iocage-plugin-plexmediaserver-plexpass.git
  These pkgs will be installed:
	- multimedia/plexmediaserver-plexpass
Error: error sending query: authority section incomplete
  File "/usr/local/bin/iocage", line 10, in <module>
	sys.exit(cli())
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 722, in __call__
	return self.main(*args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 697, in main
	rv = self.invoke(ctx)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 1066, in invoke
	return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 895, in invoke
	return ctx.invoke(self.callback, **ctx.params)
  File "/usr/local/lib/python3.6/site-packages/click/core.py", line 535, in invoke
	return callback(*args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/iocage/cli/fetch.py", line 170, in cli
	ioc.IOCage(exit_on_error=True).fetch(**kwargs)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/iocage.py", line 964, in fetch
	props, accept_license=accept)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 676, in fetch_plugin_index
	props, 0, accept_license)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 124, in fetch_plugin
	_conf, pkg, props, repo_dir)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 453, in __fetch_plugin_install_packages__
	uuid, jaildir, _conf, repo=conf["packagesite"], site=repo_name)
  File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_create.py", line 520, in create_install_packages
	raise RuntimeError(f"{dnssec_connection}\n"
RuntimeError:
Command run: drill -D http://pkg.cdn.trueos.org/iocage
This has been happening for the last week or so, previously I installed plugins fine ... with the same command.
D
dlavigne
Guest
Please create a report at bugs.freenas.org and post the issue number here.
Bernard Mentink
Bernard Mentink
Resolved: Was a dns issue .... freenas had booted without getting a nameserver, reboot solved (or manually added router IP to /etc/resolve.conf)
Bernard Mentink
Bernard Mentink
So will this be fixed anytime soon?
I just tried to install next cloud and get the same error:
sudo iocage fetch --plugins --name "nextcloud" ip4_addr="vnet0|192.168.178.205/24" defaultrouter="192.168.178.1" vnet="on" allow_raw_sockets="1"
Plugin: NextCloud
  Post-install Artifact: https://github.com/freenas/iocage-plugin-nextcloud.git
	- www/nextcloud
	- www/nginx
	- databases/mysql56-server
	sys.exit(cli())
RuntimeError:
I can ping pkg.cdn.trueos.org from FreeNAS ..
marcevan
It might be the RELEASE name you have. Can you iocage list and get that to function? If not and that throws a lot of python errors, check in your iocage jail's config.json for the release name and make it damn short.
