adamjs83
- Sep 3, 2015
I am using a SUPERMICRO MBD-X10SL7-F for me freenas box. I have 6 identical white label 6tb hard drives. Four of them are connected to the LSI controller and the other two are connected to the mobo controller. When I first installed the drives and ran the smart short and long tests the four drives connected to the LSI passed with flying colors and two connected to the mobo failed with errors. I then ran bad blocks on all drives for several days and no error were reported. I then ran short and long tests on all six drives and they all passed. One of the mobo drives is showing a reallocated sector count of 61. Does this drive need to be replaced? Smart results on the drive in question are below:
Device Model: WL6000GSA6457
Serial Number: XXXXXXXXXXXXX
LU WWN Device Id: 0 000000 000000000
Firmware Version: 01.00F.3
User Capacity: 6,001,424,400,384 bytes [6.00 TB]
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ATA8-ACS (minor revision not indicated)
Local Time is: Thu Sep 17 16:22:58 2015 EDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
data collection: ( 2624) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 680) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 1
5 Reallocated_Sector_Ct 0x0033 199 199 140 Pre-fail Always - 61
7 Seek_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 162
10 Spin_Retry_Count 0x0033 100 253 051 Pre-fail Always - 0
11 Calibration_Retry_Count 0x0032 100 253 051 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1
184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 062 056 000 Old_age Always - 38
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 0
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 114 108 000 Old_age Always - 38
195 Hardware_ECC_Recovered 0x0036 200 200 000 Old_age Always - 0
196 Reallocated_Event_Count 0x0032 197 197 000 Old_age Always - 3
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0009 200 200 051 Pre-fail Offline - 0
SMART Error Log Version: 1
ATA Error Count: 2
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 2 occurred at disk power-on lifetime: 265 hours (11 days + 1 hours)
ER ST SC SN CL CH DH
40 51 a2 51 5e 90 e0 Error: UNC 162 sectors at LBA = 0x00905e51 = 9461329
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 08 a8 5e 90 e0 08 5d+05:12:31.841 READ DMA
c8 00 08 b0 5e 90 e0 08 5d+05:12:31.831 READ DMA
c8 00 08 b8 5e 90 e0 08 5d+05:12:31.820 READ DMA
c8 00 08 c0 5e 90 e0 08 5d+05:12:31.810 READ DMA
c8 00 08 c8 5e 90 e0 08 5d+05:12:31.800 READ DMA
Error 1 occurred at disk power-on lifetime: 265 hours (11 days + 1 hours)
c8 00 00 60 5e 90 e0 08 5d+05:12:27.474 READ DMA
c8 00 00 60 5c 90 e0 08 5d+05:12:27.474 READ DMA
c8 00 10 e0 7d 09 e0 08 5d+05:12:27.392 READ DMA
ca 00 08 80 06 4c e0 08 5d+05:12:26.163 WRITE DMA
# 1 Extended offline Completed without error 00% 155 -
# 2 Extended offline Completed without error 00% 106 -
# 3 Extended offline Completed: read failure 90% 0 9436752
# 4 Short offline Completed: read failure 40% 0 9436752
2 of 2 failed self-tests are outdated by newer successful extended offline self-test # 1
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
