I recently setup TrueNAS CORE on my machine with no issues, but went to re-install SCALE to utilize Docker and other Debian apps. In TrueNAS CORE, I didn't have any issues with setting up and configuring the 10g network interface. However, in SCALE I cannot get TrueNAS to recognize the device.
When using
After running
I've seen a couple of other users deal with this issue. One of them, their device was not providing an ID, and others never got answers back from the forum threads. I did see a post where someone mentioned how it could be a BIOS issue, but I checked through all my PCI settings and everything was set properly. I'm fairly new to SCALE so any help is much appreciated.
When using
lspci
I do see the device properly listed in the active PCI devices.Code:
29:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01) 29:00.1 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
After running
dmsg | grep ixgbe
the resulting output shows this:Code:
[ 1.181133] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver [ 1.186165] ixgbe: Copyright (c) 1999-2016 Intel Corporation. [ 1.192676] ixgbe 0000:29:00.0: enabling device (0000 -> 0002) [ 1.214032] ixgbe 0000:29:00.0: Adapter removed [ 1.218122] ixgbe: probe of 0000:29:00.0 failed with error -5 [ 1.224237] ixgbe 0000:29:00.1: enabling device (0000 -> 0002) [ 1.246793] ixgbe 0000:29:00.1: Adapter removed [ 1.253200] ixgbe: probe of 0000:29:00.1 failed with error -5
