Just built a new freenas server using a Supermicro X9SCM-F-O board which has on board dual gigabit lan via the Intel 82579LM & 82574L. The problem I'm having is that freenas seems to be detecting one of the cards as 100mbps and the other at the correct speed of 1000mbps. The LED's on the back of the cards also seem to indicate a 100 mbps speed on one of the ports. I've tried changing cable and also tried a different switch port. Both cards are plugged into the same switch. I'm not sure where to begin troubleshooting. Any help would be very much appreciated.
Thanks,
Andy
Thanks,
Andy
