I just installed FreeNAS and then try to install Transmission plugin and the installation fails at the "5/6 creating jail" stage. Below is the error message it gives - if there's someone who can make any sense of this, could he please kindly explain what should I do about it to make it work. Thanks in advance!
Request Method: POST Request URL: http://192.168.10.6/plugins/plugin/install/cf70cca69137d5882d7d8f95892099573b19a18e89eeaf707a09741c8187fdf6/ Software Version: FreeNAS-11.0-U4 (54848d13b) Exception Type: MiddlewareError Exception Value: [MiddlewareError: b"Failed to install plugin: [warden_exception: cannot open 'test/jails/.warden-template-pluginjail@clean': dataset does not exist\nERROR: Failed creating clean ZFS base clone\n]"] Exception Location: ./freenasUI/jails/utils.py in new_default_plugin_jail, line 721 Server time: Sun, 29 Oct 2017 08:53:32 +0900 Traceback Environment: Software Version: FreeNAS-11.0-U4 (54848d13b) Request Method: POST Request URL: http://192.168.10.6/plugins/plugin/install/cf70cca69137d5882d7d8f95892099573b19a18e89eeaf707a09741c8187fdf6/ Traceback: File "./freenasUI/jails/utils.py" in new_default_plugin_jail 718. w.create(**create_args) File "./freenasUI/common/warden.py" in create 1097. return self.__call(warden_create(flags, **kwargs)) File "./freenasUI/common/warden.py" in __call 1070. tmp = obj.run() File "./freenasUI/common/warden.py" in run 465. raise warden_exception(msg) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 39. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/plugins/views.py" in install_available 306. raise e File "./freenasUI/plugins/views.py" in install_available 302. jail = new_default_plugin_jail(plugin.unixname) File "./freenasUI/jails/utils.py" in new_default_plugin_jail 721. raise MiddlewareError(_("Failed to install plugin: %s") % e) Exception Type: MiddlewareError at /plugins/plugin/install/cf70cca69137d5882d7d8f95892099573b19a18e89eeaf707a09741c8187fdf6/ Exception Value: [MiddlewareError: b"Failed to install plugin: [warden_exception: cannot open 'test/jails/.warden-template-pluginjail@clean': dataset does not exist\nERROR: Failed creating clean ZFS base clone\n]"] Request information GET No GET data POST Variable Value __form_id 'form_str' FILES No FILES data COOKIES Variable Value csrftoken 'Qzo6HIIaORXzyvcEQ92Ry8hlzHgFjsC79j28phkcJPqXLZVqjNfIxlTeEks9v89S' fntreeSaveStateCookie 'root%2Croot%2F25%2F35' sessionid 'vzp3r37yv77pth9iyy1wnz3q6ktab2t6' META Variable Value
