nathank1989
- Aug 29, 2016
I just installed the radarr plugin to give it a try and really liked it, so no I want to set up Sonarr.
I tried doing the same thing I did for Radarr, Plugins->Available Plugins->Sonarr->Install
Left all at default, and the jail name is "sonarr"
But I get this error:
Can I not have both plugins installed? Should I just install Sonarr on the same jail as Radarr?
On Freenas 11.2-BETA2
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 662, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 248, in fetch
iocage.fetch(**options)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/iocage.py", line 909, in fetch
props, accept_license=accept, official=official)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 690, in fetch_plugin_index
props, 0, accept_license)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 125, in fetch_plugin
props, jail_name)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 306, in __fetch_plugin_create__
exit_on_error=self.exit_on_error).create_jail()
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_create.py", line 88, in create_jail
return self._create_jail(jail_uuid, location)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_create.py", line 104, in _create_jail
raise RuntimeError(f"Jail: {jail_uuid} already exists!")
RuntimeError: Jail: radarr already exists!
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run
await self.future
File "/usr/local/lib/python3.6/asyncio/coroutines.py", line 129, in throw
return self.gen.throw(type, value, traceback)
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 356, in __run_body
rv = await self.middleware._call_worker(self.serviceobj, self.method_name, *self.args, job={'id': self.id})
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 977, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 908, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 902, in run_in_executor
