SOLVED Installing Sickrage on 11.2, Shebang Error
Chris Dill
I did this: https://forums.sickrage.ca/t/how-to-install-on-freenas/19
And afterwards I get this:
root@POOL2:/mnt # iocage exec sickrage service sickrage restart
/usr/local/etc/rc.d/sickrage: WARNING: no shebang line in /usr/local/bin/python2.7
root@POOL2:/mnt #
I am sure it is an easy fix, but searching around has not lead me to the solution. Anyone know how to correct this?
SavageAUS
I believe sickrage is now sickchill. I personally use Sonarr.
Chris Dill
I switched to Sonarr since my SickRage config was broken anyhow. Working well, thanks for the tip!
SavageAUS
No problem, if you also install jackett in a jail you can use that to add indexers.
