Installing FreeNAS on Plextor M6e SSD
Michael Mead
I'm installing FreeNAS on a new server and I'd like to use a PCI-E Plextor drive (PX-AG128M6e) for the installation drive. It is recognized in the BIOS, but it is not visible in the FreeNAS installation drive selection menu. It uses the Marvell 88SS9183 controller. Is there a way for me to manually add drivers to the installation?
Other info:
Motherboard: SuperMicro X10SLM+-LN4F,
CPU: E3-1231V3
No.
In addition, that thing is major overkill for FreeNAS. It literally cannot be used for anything other than the FreeNAS install.
Michael Mead
I would like to use it for the FreeNAS install, but FreeNAS is not recognizing the drive in the installation menu. If I cannot add drivers, is there anyway to install FreeNAS on this drive?
Some drives support some kind of SATA/AHCI emulation mode, from what I've read, but I haven't messed around with them.
Nope. That hardware isn't recommend and isn't supported (as is obvious from the fact you can't install to it).
KempelofDoom
Other info:
CPU: E3-1231V3
Any specific reason you don't want to install to a USB thumbdrive? It's the recommended method for installation.
