installed plugin, no web gui
Evelen
Do I have to do anything special before the web gui is available? This is all I get when i click manage on the plugin after installation.
10.0.24.114
IPv6 Address:
N/A
Version:
1.34.9
Plugin:
zoneminder
Release:
11.3-RELEASE-p9
Collection:
Did you see an IP address for the plugin? (you can usually see it under Jails in the FreeNAS GUI)
OK, so I just installed it to have a look...
What's happening is that the web server isn't properly configured for https... even though the plugin shows you that the web interface is at https://10.0.24.114/zm it's actually at http://10.0.24.114/zm
I'm having a similar problem. I foolishly hit the update button in the plugin, zoneminder area. Now I get the dreaded
"This site can’t be reached" notice.
I tried the ip address both as cast so with https and also keyed in the ip address with http only. (in the browser address bar)
I have been busy with other projects so haven't done much rtfm for which I apologize in advance.
Anyone have any ideas off the tops of their heads of an easy fix that I haven't considered. otherwise I'll either RTFM! or reinstall with the earlier version, which last time I looked worked.
