Installed on Laptop Hard Drive
Hi, a friend asked me to fix his laptop. Apparently, he installed Freenas on his hard drive instead of the flash drive. Now the machine won't boot from either the usb drive or dvd drive. I tried a windows disk and a dban disk but nothing works. It just takes me right to a grub menu.
Thanks,
Vince
BigDave
FreeNAS Enthusiast
Have you tried going into the BIOS and changing the boot order?
How do I do that if it just goes right into the grub menu. It won't let me get to the bios even if I hold down F2.
Then I end up at the Freenas Console.
gpsguy
Active Member
If you can't do it on the laptop, remove the hard disk temporarily and wipe it on another machine.
Tell your friend that laptops aren't a good choice for FreeNAS, for a lot of reasons. For starters, FreeNAS requires 8GB of RAM and ECC is recommended.
BigDave
FreeNAS Enthusiast
I don't want to come off as harsh here, but to be honest with you, if you can't figure out how to
boot into the laptop's BIOS, perhaps you should not be the one to help your friend???
Robert Trevellyan
Pony Wrangler
Assuming F2 is the right key, tap rapidly instead of holding it. But double check the manual for the specific model of laptop, you might need to use a different key.
An alternative to changing the BIOS boot order setting is a one-time boot device selection menu, which is usually F12.
pirateghost
Unintelligible Geek
Not much help Dave, you didn't even tell me how to do it!!!
That's enough.
You cannot come in here and demand volunteers help you with a problem that you can resolve using Google. This isn't a freenas issue. At. All.
jgreco
Resident Grinch
mod note: evicted from the FreeNAS forums, to offtopic.
mod note 2: please play nicely with the fellow who's obviously frustrated
DrKK
FreeNAS Generalissimo
joeschmuck
Old Man
The user has been banned.
jgreco
Resident Grinch
Actually the note says the user was "Baned."
latest
which also seems strangely appropriate.
joeschmuck
Old Man
lol, you crack me up.
joeschmuck
Old Man
That I did.
