Installation questions
Hello, I have a doubt to deploy FreeNas in the small company where I work, I have the following configuration:
HP Proliant server, xeon processor 3.30ghz, 20gb of ram.
My doubt is can I install freenas with just 1 hd and then add another hd just like to perform RAID 1 to mirror the data?
You need a disk to run the OS (can be SSD or USB). You can't use that disk for data.
If you have a single disk pool and want to mirror it by adding a second disk, the option in the GUI is missing right now, but will return soon, you can do it in the meantime by Command Line.
você pode me dizer qual versão faz isso através da GUI? ou onde eu acho que faço a linha de comando para essa alteração?
can you tell me which version does this through the gui? or where do I think I make the command line for this change?
