HI i am having trouble installing 11.3 on my old PC
hardware
Motherboard B85M-E
CPU intel core I7 4790 3.6ghz
RAM 16gb 1600MHz
Boot device m.2 128gb kingston connected to PCIe
After i choose where to install the device this shows up :
gmirror: No such device: swap.
2+0 records in
2+8 records out
2097152 bytes transferred in 0,018904 secs (110937080 bytes/sec)
dd: /dev/nvd0: short write on character device
dd: /dev/nvd0: end of device
3+0 records in
2+1 records out
2449409 bytes transferred in 0.00448 secs (1513561811 bytes/sec)
nvd0 created
nvd0p1 added
nvd0p2 added
nvd0 destroyed
nvd0 created
nvd0pl added
nvd0p2 added
active set on nvd0
File "/usr/local/bin/freenas-install", line 59, in <module>
if installer.GetPackages() is not True:
File "/usr/local/lib/freenas0S/Installer.py", line 1072, in GetPackages
pkgFile = self._conf.FindPackageFile(pkg, handler=get_file_handler)
File "/usr/local/lib/freenasOS/Configuration.py", line 1273, in FindPickageFile
raise pkg_exception
freenas0S.Exceptions.ChecksumFailException: %freebsd-pkgdb-13.0-U4-734ab7bf672f7437fbc23885c07eebac.tgz has invalid checksum
The TrueNAS installation on nva has failed. Press enter to continue...
hardware
Motherboard B85M-E
RAM 16gb 1600MHz
2+0 records in
2+8 records out
3+0 records in
2+1 records out
nvd0 created
nvd0p1 added
nvd0p2 added
nvd0 destroyed
nvd0 created
nvd0pl added
nvd0p2 added
active set on nvd0
raise pkg_exception
