install fswatch for freenas
jianmoto
I want to install a file monitoring tool named fswatch for freenas so that I can monitoring some dir of freenas.But I don't know how to add the package into freenas. Is there any solution?
thanks
jianmoto
What I want to monitor is not datasets, in an other word,I want to monitor /mnt (all data of freenas).
jianmoto
I want to look at the source code and then add the package into the codes.And rebuild the freenas.
anodos
Sambassador
And then? What is the goal (other than I want to run software X on FreeNAS)? There might be a better way to accomplish it other than jacking around with the FreeNAS source.
SweetAndLow
Sweet'NASty
Modifying the freenas system isn't the way things work. When using software on freenas you install it in a jail and mount your pool in that jail.
jianmoto
OK, I'll have a try.I think it is very hard to change the source codes,too.
SweetAndLow
Sweet'NASty
jianmoto
http://www.freshports.org/security/fswatchfswatch
This is the port you can install and I have to ask can zfs snapshots solve your problem? Or are you looking for an audit solution?
I want to look for an audit solution,and change the mode of file when the file change.
This is the fswatch.
http://pkg.freebsd.org/freebsd:9:x86:64/latest/All/fswatch-0.02.b5.txz
But it is the old version of fswatch,sometimes doesn't work.I want to install the latest version of fswatch
http://emcrisostomo.github.io/fswatch/
jianmoto
It cann't install in the jail,because jails only can mount the dataset so that I cann't monitor all data of freenas.And I can change the mode of file in the jails.
SweetAndLow
Sweet'NASty
Mount all your data in the jail then.
jianmoto
The reason to install fswatch is to change the mode of files(when they change the file name or the files are new.).And it should be compulsory to monitor the data(not configure by any user).By the way audit.The secure audit mechanism should be compulsory,too.
