And then? What is the goal (other than I want to run software X on FreeNAS)? There might be a better way to accomplish it other than jacking around with the FreeNAS source.I want to look at the source code and then add the package into the codes.And rebuild the freenas.
OK, I'll have a try.I think it is very hard to change the source codes,too.Modifying the freenas system isn't the way things work. When using software on freenas you install it in a jail and mount your pool in that jail.
I want to look for an audit solution,and change the mode of file when the file change.http://www.freshports.org/security/fswatchfswatch
This is the port you can install and I have to ask can zfs snapshots solve your problem? Or are you looking for an audit solution?
