Motherboard : HP DL380e G8
CPU : 2 x E52450
RAM : 128GB
Hard drives 1x 3TB IBMESXS (boot) + 4 x 10TB Seagate Ironwolf Pro
HBA : LSI SAS 9207 8i PCI3
NIC : onboard 1gb + 10Gb SolarFlare SFN7002F SFP+ Dual-Port 10GbE Flareon PCIe 3.0
After installing truenas all looked fine and tested read and write speed from an nfs client - seemed ok.
Then I did two things after which truenas started shutting itself down even after restarts - it stayed up for about 3 minutes i think.
The two things : from system off state I plugged in the 10gb cable and started the system - all seemed fine then shortly after that I enabled ssh service from the web app.
About a minute later the truenas went into a shut down.
After restart it shut down again after about 2 or 3 minutes - just enough for me to find that the ssh enablement was reverted seemingly automatically.
I also disconnected the 10gb card - made no difference.
Very hard to debug because the machine keeps shutting itself down after rebooting - so I can't look at any log files !
Any recommendations ? how do you examine log files ?
CPU : 2 x E52450
RAM : 128GB
