- Nov 25, 2013
Hi, @ornias,
just a push in the right direction, please.
If I want to run multiple TrueCharts applications on my host, all on port 443 with SNI, should I look into the "ingress" section of the settings or this part of the manual?
Curiously the manual does not mention "ingress". At least not in the navigation.
Or are these the same and it's only a matter of terminology and organisation of the docs?
If have a wildcard certificate for my internal domain, and I already found the part about using the TN SCALE certificate store. All understood. Now how to get foo.ettlingen.hausen.com and bar.ettlingen.hausen.com to different node ports?
Thanks!
Patrick
Thanks!
Patrick
