Importing config database from 9.2 to 9.2.1.1
I try to update my usb stick from 9.2 to 9.2.1.1.
The update seemed ok but after reboot, nothing is available although its ip is working.
I also tried to make a new install on usb and importing config via GUI but the result is the same :
i cant log on http nor command line.
What did i miss ?
Best regards
David
D
dlavigne
Guest
It's unclear what the problem is. You get to the GUI login prompt and can't login? If so, are you using root as the username?
Yes i log using root
The webGUI doesn't load, i've got a http error.
And at the command line, my password is not accepted too...
David
I don't know what to show you because once config database is uploaded and the server rebooted, the shares don't work anymore as the webUI.
I have the console but i have on my usb stick only "var/log@" on the 9.2.1.1 which is not readable.
I join the dmesg result of each system 9.2 and 9.2.1.1. even if i don't see anything interesting about my problem.
I don't know if i can join my config database (privacy issue ?)
  • dmesg92.txt
  • dmesg9211.txt
tarvr
Hallo,
Here the same problem upgrade from 9.2.1 to 9.2.1.1 – No Web Gui not working. IP address working.
Clean install 9.2.1.1 – WebGui working. Upload config. After reboot WebGui not working.
Then clean install 9.2.1 and upload config – Everything working again.
D
dlavigne
Guest
Sounds like a bug then. Please create a ticket at bugs.freenas.org and post the issue number here.
