Raj Rajagopal
 - Feb 21, 2014
I upgraded my FreeNas from 9.2 to 9.2.1.1 using the web UI method.
Everything seemed to go through fine but after the reboot (during which I see couple of warning relating to 'failed precmd routine for vmware_guest' and 'unable to start syslogd'. After these messages, either the system continues to boot fine or awaits at the loading kernel modules for a really long time (15+ minutes).
Finally, the boot sequence completes and I see the freenas home menu (options 1-11). I can access the web UI at this point. But, the system automatically restarts within 5 to 10 minutes. This has been going on every since my upgrade and I can't find anything else in the var/log/messages (possibly due to syslogd down?).
Any help on debugging this? I also have my 9.2 DB backed up, should I just revert back 9.2 or can I do a clean install 9.2..1.1 and import the DB?
Thanks,
Thanks,
