Imported my Volume, but 1 of 6 data sets wont show in GUI
Simplicity
Hi All,
I did a fresh install of FreeNAS and successfully imported my old ZFS Volume1. It showed all my datasets except for my "Movies" dataset.
The weird part is, even though it doesnt show on the left hand side, the data set still exists! I can access all the movies in the directory and it wont let me create a new dataset with the same name, as it says a folder already exists with same name!
Why cant my Movies dataset populate on the left hand tool bar? My Music/Apps/Downloads/Pics datasets work fine and show up.
Any idea?
SweetAndLow
Sweet'NASty
I agree with @danb35, you don't have a movies dataset you have a movie folder. Nothing has changed this is how you had it configured before the fresh install you just didn't know it was setup this way.
