Hi there,
After trying to find information about this for several days I am ready to admit that I can not do this by myself.
I am sure this is an easy cherry for some of you, so I am handing over the fate of my my data into more capable hands...
The situation:
I had 3 geli-encrypted drives that were initialized in FreeNAS 9.x using ZFS and were running just fine in single configuration, no raid.
My plan was to add a 4th, which I did. After the next boot, one of the 3 disks did not decrypt anymore.
Some research indicated that this issue might be fixed with detaching and reimporting the drive.
I detached it just to find out that it now does not appear in the import volume dialog. It is listed in the [Storage>Volume>View Disks] though.
To check if my import skills are just not good enough, I created the 4th encrypted drive and detached it. Same problem. Gives me hope that the drive is not forfeit though.
I guess my importing skills suck.
ada0 and ada1 are running as intended
ada2 is the drive that had the decryption trouble and ada3 is the new drive (both were detached)
Here is the gpart list output
Could anyone run me through the steps that I have to do to import both drives using the shell? I am handing out karma points!
Thanks in advance and let me know which further output is needed!
Regards
elunder
The situation:
Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada0p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 0cd54fbc-3cd7-11e3-a009-94de80048cac rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada0p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 0ce7df3d-3cd7-11e3-a009-94de80048cac rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada0 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 8af59959-4007-11e3-82ae-94de80048cac rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 8b0b0b1d-4007-11e3-82ae-94de80048cac rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 Geom name: ada3 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 5305cd6e-3b24-11e7-a332-94de80048cac rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada3p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 531820c0-3b24-11e7-a332-94de80048cac rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada3 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 30867422 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da0p1 Mediasize: 524288 (512K) Sectorsize: 512 Stripesize: 0 Stripeoffset: 17408 Mode: r0w0e0 rawuuid: 5ffe34c7-fa36-11e4-889b-6cf049054279 rawtype: 21686148-6449-6e6f-744e-656564454649 label: (null) length: 524288 offset: 17408 type: bios-boot index: 1 end: 1057 start: 34 2. Name: da0p2 Mediasize: 15803572224 (15G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 544768 Mode: r1w1e2 rawuuid: 60059b3d-fa36-11e4-889b-6cf049054279 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 15803572224 offset: 544768 type: freebsd-zfs index: 2 end: 30867415 start: 1064 Consumers: 1. Name: da0 Mediasize: 15804137472 (15G) Sectorsize: 512 Mode: r1w1e3
Regards
elunder
