SOLVED Import encrypted pool after upgrade to latest beta
hugovsky
I've installed freenas 9.3 beta and created an encrypted pool to test it. I've now tried to update it from console and after reboot, I was presented with an empty volume. I tried to import pool with key and passphrase and when the pool is decrypted, it shows that I have a pool with that name already. Am I doing it wrong or is this an error? Specs below. Thanks.
FreeNAS-9.3-BETA-1416270131-1
Supermicro A1SAi-2750F with 16 GB ECC ram
4x WD red 1 TB
boot from usb 8GB pen drive
Pool is 2x2 mirror.
I have a debug file I can provide if you think it's needed.
Reverting back to default install (initial downloaded cd-rom image) on usb stick, gives same problem. Didn't try to re-install and import.
D
dlavigne
Guest
Please create a bug report at bugs.freenas.org that includes the debug file and post the issue number here.
It appears the using encrypted pools on 9.3 is pretty broken?!?
J
jkh
Guest
We are aware of the encrypted pool import issue - we're working to fix the issue now. Thanks
