Enable auto tune... yes or no?
hugovsky
I'm running freenas 9.3-beta with recent update installed on a 8GB usb drive. I have 16 ECC ram running on a A1SAi-2750F. RAIDZ2 with 4 reds 1TB each. Do you think I should enable autotune? I'm using the nas at home. CIFS, AFP and unix shares but no real load. What's the best tests I can use to determine perfomance? I can destroy the pool I'm using if needed to test. My basic question is to know if I should at least try it or not.
Norleif
One tuning option that isn't in "auto tuning" would be to change your 4-drive RAIDZ2 to striped mirrors...
Fraoch
I've read here that autotune should be used only in 16GB+ ram systems.
Ouch, would you mind posting where you found that?
I'm using autotune. I haven't experienced problems but I was not aware you needed more than 16 GB of RAM in order to use it.
hugovsky
Here. But it may be off because it's a diferent freenas version and more than a year old post.
this is my pool now:
pool: tank
state: ONLINE
  scan: none requested
        NAME                                                STATE     READ WRITE CKSUM
        tank                                                ONLINE       0     0     0
          mirror-0                                          ONLINE       0     0     0
            gptid/0859fde3-6c1d-11e4-949f-002590f52106.eli  ONLINE       0     0     0
            gptid/0999d18d-6c1d-11e4-949f-002590f52106.eli  ONLINE       0     0     0
          mirror-1                                          ONLINE       0     0     0
            gptid/0b4beb5b-6c1d-11e4-949f-002590f52106.eli  ONLINE       0     0     0
            gptid/0c4aa1f1-6c1d-11e4-949f-002590f52106.eli  ONLINE       0     0     0
But now I can't have 2 drives failing at the same time like raidz2, right? Or can I?...
RobertT
two drives in one mirror could fail but if one drive in each mirror fails you are hosed.
mjws00
mjws00
No. Each mirrored pair is a vdev. All vdevs must be present. You can lose one drive from each pair and still have sufficient replications of your data for a healthy pool. Mirrors resilver faster and have more iop potential. Raidz2 allows that extra drive to fail that would hurt you in a mirrored solution. Both are safe, mirrors are best practice for performance.
gpsguy
Active Member
RobertT has it backwards. You can't loose 2 disks in a mirror (vdev) without loosing your pool. You could loose one disk in each of the mirrors without loss.
Sent from my phone
