hugovsky
 - Dec 12, 2011
I'm running freenas 9.3-beta with recent update installed on a 8GB usb drive. I have 16 ECC ram running on a A1SAi-2750F. RAIDZ2 with 4 reds 1TB each. Do you think I should enable autotune? I'm using the nas at home. CIFS, AFP and unix shares but no real load. What's the best tests I can use to determine perfomance? I can destroy the pool I'm using if needed to test. My basic question is to know if I should at least try it or not.
