Elliot Dierksen
- Dec 29, 2014
I did some forum searching to see if setting vfs.zfs.arc_max is required/recommended. I know it would be if you are running VM's and you want to make sure some memory is reserved for the VM's, but that is not my use case. I am running my units bare metal storage only. Both units are Cisco C240 M4's with 256G RAM, E5-2637 v3 CPU's, LSI 3108 based HBA, Chelsio T580 40G NIC's on the storage side. My gut is that I shouldn't need vfs.zfs.arc_max, but I don't want to shoot myself in the foot. This was all brought to mind by a recent post from @Spearfoot regarding 10G network tuning. Both units are tuned the same as follows:
I did have auto-tune enabled at one point, but it isn't enabled now. I used that as a starting point. My desire is to wring as much performance out of my 40G connections as possible. Both units have an Optane 900P SLOG on each pool since I use NFS from ESXi 6.7 for sharing storage to the ESXi hosts.
Variable Value Type Description Enabled dev.t5nex.0.toe.ddp 1 sysctl T5 manual tune no dev.t5nex.0.toe.tx_zcopy 1 sysctl T5 manual tune no hw.pci.honor_msi_blacklist 0 loader Spearfoot yes kern.ipc.maxsockbuf 16777216 sysctl Soearfoot yes kern.ipc.nmbclusters 16352042 sysctl Generated by autotune yes kern.ipc.soacceptqueue 1024 sysctl Spearfoot yes net.inet.ip.intr_queue_maxlen 2048 sysctl Spearfoot yes net.inet.tcp.blackhole 2 sysctl Disable firewall no net.inet.tcp.delayed_ack 0 sysctl Generated by autotune yes net.inet.tcp.mssdflt 1448 sysctl Generated by autotune yes net.inet.tcp.recvbuf_inc 4194304 sysctl Spearfoot yes net.inet.tcp.recvbuf_max 16777216 sysctl Spearfoot yes net.inet.tcp.recvspace 4194304 sysctl Spearfoot yes net.inet.tcp.sendbuf_inc 4194304 sysctl Spearfoot yes net.inet.tcp.sendbuf_max 16777216 sysctl Spearfoot yes net.inet.tcp.sendspace 4194304 sysctl Spearfoot yes net.inet.udp.blackhole 1 sysctl Disable firewall no net.route.netisr_maxqlen 2048 sysctl Spearfoot yes vfs.usermount 1 sysctl Replication no vfs.zfs.arc_max 247311000000 sysctl Generated by autotune yes vfs.zfs.dirty_data_max 34359738368 sysctl Manual tune to 32G yes vfs.zfs.l2arc_headroom 2 sysctl Generated by autotune yes vfs.zfs.l2arc_noprefetch 0 sysctl Generated by autotune yes vfs.zfs.l2arc_norw 0 sysctl Generated by autotune yes vfs.zfs.l2arc_write_boost 40000000 sysctl Generated by autotune yes vfs.zfs.l2arc_write_max 10000000 sysctl Generated by autotune yes vfs.zfs.metaslab.lba_weighting_enabled 1 sysctl Generated by autotune yes vfs.zfs.zfetch.max_distance 33554432 sysctl Generated by autotune yes
