Just wanted to share some results i found while looking for a good device for a ZIL; haven't seen much in actual numbers while searching before.
O/C this is not necessarily reproducible for everyone so treat it as ballpark number; its not a scientific test either;)
Base array is a 4x2SATA3 Mirror (5940 RPM), i added the following:
-Intel SSD 510 120GB ~50MB/s
-Dell Perc 5/i with BBU/512MB Cache,
and an old slow 2,5" HDD/2 x250 GB 3,5 in Raid0 - both ~40-50 MB/s
-IBM M5015 - way slower than Dell Perc for some reason
-HGST SSD400M ~150MB/s
This last one is slightly slower than an Intel DC3700 so that should provide another boost.
All tests where run with large file copy initially and sync=always; I cross-checked the last with ESXi, VMWare Creation and CrystalDiskMark, albeit only on 1GB connection but got ~100 MB so i assume its valid.
The SSD400M is o/c not the most likely candidate but its currently obtainable fairly cheap in the bay over here.
I can run some more tests if anyone is interested and time permits
Edit: Will try to use a more complete approach as suggested below; this will take some time though.
Just forgot to mention those results above where with cifs but sync=always to simulate ESXi behaviour.
