I just received critical error:
CRITICAL
Failed to check for alert VolumeStatus: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 115, in main_worker res = MIDDLEWARE._run(*call_args) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 46, in _run return self._call(name, serviceobj, methodobj, args, job=job) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 34, in _call with Client(f'ws+unix://{MIDDLEWARE_RUN_DIR}/middlewared-internal.sock', py_exceptions=True) as c: File "/usr/lib/python3/dist-packages/middlewared/client/client.py", line 326, in __init__ self._ws.connect() File "/usr/lib/python3/dist-packages/middlewared/client/client.py", line 129, in connect rv = super(WSClient, self).connect() File "/usr/lib/python3/dist-packages/ws4py/client/__init__.py", line 222, in connect bytes = self.sock.recv(128) socket.timeout: timed out """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/alert.py", line 776, in __run_source alerts = (await alert_source.check()) or [] File "/usr/lib/python3/dist-packages/middlewared/alert/source/volume_status.py", line 19, in check for pool in await self.middleware.call("pool.query"): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1386, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1335, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1318, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/service.py", line 927, in query result = await self.middleware.call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1386, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1335, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1318, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 165, in query result = await self._queryset_serialize( File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 217, in _queryset_serialize return [ File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 218, in await self._extend(data, extend, extend_context, extend_context_value, select) File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/read.py", line 231, in _extend data = await self.middleware.call(extend, data, extend_context_value) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1386, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1346, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1249, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 605, in pool_extend pool |= self.middleware.call_sync('pool.pool_normalize_info', pool['name']) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1405, in call_sync return self.run_coroutine(methodobj(*prepared_call.args)) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1445, in run_coroutine return fut.result() File "/usr/lib/python3.9/concurrent/futures/_base.py", line 433, in result return self.__get_result() File "/usr/lib/python3.9/concurrent/futures/_base.py", line 389, in __get_result raise self._exception File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1318, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 565, in pool_normalize_info if info := await self.middleware.call('zfs.pool.query', [('name', '=', pool_name)]): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1386, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1343, in _call return await self._call_worker(name, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1349, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1264, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1249, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) socket.timeout: timed out
2023-04-23 22:21:48 (Europe/Rome)
Dismiss
Hardware details:
8x Toshiba MG08ACA16TE
4 attached to motherboard sata. 4 attached on pci sata multiplier 4x
root@truenas[~]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 14.6T 0 disk
├─sda1 8:1 0 2G 0 part
│ └─md127 9:127 0 2G 0 raid1
│ └─md127 253:1 0 2G 0 crypt [SWAP]
└─sda2 8:2 0 14.6T 0 part
sdb 8:16 0 14.6T 0 disk
├─sdb1 8:17 0 2G 0 part
└─sdb2 8:18 0 14.6T 0 part
sdc 8:32 0 14.6T 0 disk
├─sdc1 8:33 0 2G 0 part
│ └─md126 9:126 0 2G 0 raid1
│ └─md126 253:3 0 2G 0 crypt [SWAP]
└─sdc2 8:34 0 14.6T 0 part
sdd 8:48 0 14.6T 0 disk
├─sdd1 8:49 0 2G 0 part
└─sdd2 8:50 0 14.6T 0 part
sde 8:64 0 14.6T 0 disk
├─sde1 8:65 0 2G 0 part
│ └─md124 9:124 0 2G 0 raid1
│ └─md124 253:0 0 2G 0 crypt [SWAP]
└─sde2 8:66 0 14.6T 0 part
sdf 8:80 0 14.6T 0 disk
├─sdf1 8:81 0 2G 0 part
│ └─md125 9:125 0 2G 0 raid1
│ └─md125 253:2 0 2G 0 crypt [SWAP]
└─sdf2 8:82 0 14.6T 0 part
sdg 8:96 0 14.6T 0 disk
├─sdg1 8:97 0 2G 0 part
└─sdg2 8:98 0 14.6T 0 part
sdh 8:112 0 14.6T 0 disk
├─sdh1 8:113 0 2G 0 part
└─sdh2 8:114 0 14.6T 0 part
nvme0n1 259:0 0 1.8T 0 disk
├─nvme0n1p1 259:1 0 1M 0 part
├─nvme0n1p2 259:2 0 512M 0 part
├─nvme0n1p3 259:3 0 1.8T 0 part
└─nvme0n1p4 259:4 0 16G 0 part
root@truenas[~]#
