Motherboard make and model - Supermicro X9SCL-F
CPU make and model - Intel Core i3-2120
RAM quantity - 24 GB ECC
Hard drives - 7x 3 TB Drives
Hard disk controllers - IBM ServeRAID M1115 / LSI SAS9223-8i
Network cards - None
Built this home server in 2016 everything has been working fine. I booted it up yesterday (hardware unchanged) after not using it for about 12 months and FreeNAS is not seeing any of my drives. I have checked all the cables and you can feel the hard drives spinning. If I connect a hard drive to the motherboard SATA it is detected fine.
Using sas2flash -listall i get this
I have updated Freenas and tried booting on 11.2-RC1, 11.2-RELEASE-U1, 11.2-U7 and 11.3 RELEASE same issue on all.
Any help would be appreciated, I googled around a lot but I couldn't find anyone with a similar issue.
LSI Corporation SAS2 Flash Utility Version 16.00.00.00 (2013.03.01) Copyright (c) 2008-2013 LSI Corporation. All rights reserved Adapter Selected is a LSI SAS: SAS2008(B2) Num Ctlr FW Ver NVDATA x86-BIOS PCI Addr ---------------------------------------------------------------------------- 0 SAS2008(B2) 20.00.07.00 14.01.00.08 No Image 00:02:00:00 Finished Processing Commands Successfully. Exiting SAS2Flash.
