Firmware for DELL SAS 6GB/S SATA 8-PORT LSISAS2008-IT
Gibby
So I got 2 cards from View: http://www.ebay.com/itm/121431653923
and I am trying to figure out:
a)Which LSI card does this map to? I am thinking 9211-8i or 9210-3i
b)Where do I download the stinking phase 16 firmware for this thing at?
I have been searching the forums, google and dell for the better part of the day. Thanks
Here is output I see on freenas:
[root@new_nas] ~# dmesg|grep -i mps
mps0: <LSI SAS2008> port 0x3000-0x30ff mem 0xd8440000-0xd844ffff,0xd8400000-0xd843ffff irq 16 at device 0.0 on pci8
mps0: Firmware: 07.15.08.00, Driver: 16.00.00.00-fbsd
mps0: IOCCapabilities: 185c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,IR>
mps1: <LSI SAS2008> port 0x4000-0x40ff mem 0xd8740000-0xd874ffff,0xd8700000-0xd873ffff irq 18 at device 0.0 on pci9
mps1: Firmware: 07.15.08.00, Driver: 16.00.00.00-fbsd
mps1: IOCCapabilities: 185c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,IR>
da0 at mps1 bus 0 scbus1 target 12 lun 0
[root@new_nas] ~# sas2flash -listall
LSI Corporation SAS2 Flash Utility
Version 14.00.00.00 (2012.07.04)
Copyright (c) 2008-2012 LSI Corporation. All rights reserved
        Adapter Selected is a LSI SAS: SAS2008(B2)
Num   Ctlr            FW Ver        NVDATA        x86-BIOS         PCI Addr
0  SAS2008(B2)     07.15.08.00    07.00.00.19    07.11.10.00     00:08:00:00
1  SAS2008(B2)     07.15.08.00    07.00.00.19    07.11.10.00     00:09:00:00
        Finished Processing Commands Successfully.
        Exiting SAS2Flash.
LSI 9211/IBM M1015
More important than the model number is the controller it uses - the LSI SAS 2008, which is just what you need.
LSI should have an archive of old firmware versions in their download section, but you have to dig a bit to find it.
So any SAS2008 firmware will work?
Well, LSI's SAS 2008 firmware will work. All others are probably the same, but I haven't checked.
