inman.turbo
- Aug 27, 2019
As a preliminary to upgrading all my systems to truenas core I installed on a Dell Poweredge R440 (No Raid/ Software Raid Set to AHCI, 8 x 2.5 inch SATA) with half the backplane (4 X 2.5'' SATA) on LSI HBA. Same system was stellar with freenas. This version gives me thousands of cam errors and other oddness, keeps saying the device is reset. I feel like I am missing something obvious here. I've never had so much trouble. First I brought up an old pool and it said a disk was degraded. I replaced that then it said the other two were degraded. Tried a pool with just the new disk and ran fine for few hours then suspended the pool for I/O errors. Replaced HBA and moved to new slot, replaced cables and all disks, same. I can create a pool then it only works for a little while. Then only after several reboots I can destroy/export and create again. I notice that auto trim can now be manually turned on and I tried that a couple iterations but didn't seem to work. Any insights here?
Sorry I don't have any logs RN. I booted back to legacy freenas just to make sure that still works and I'm not going crazy. If anyone wants more info I'd be happy to boot back to Truenas and collect some logs.
All disks are sata ssd. 3 Western Digital Red 2TB (WDS200T1R0A). Also 1 intel s3700 was trying to use as control during experimentation. (I also use them for write protection in production on sata backplanes).
Current Train: TrueNAS-12.0-STABLE
No updates available.
