I've been running the latest 12.0 truenas core (not sure exactly which level cause I cant get into it, hence the sinking feeling but I think it was 12.0.8-U2) for some time now with no issues. I very often have the dashboard window open, so I keep close tabs daily on the system and have never seen a single hiccup. I'm using windows/smb shares for some local desktops, a handful of jails for plesk & friends, and 4 or 5 byhve vm's (1 windows, 1 freebsd, and a few debian). I keep it updated so I'm pretty sure I am on the last/latest 12x release. I was planning on going to rel 13 sometime soon since I noticed it showed up in the updater as general deployment ready, but did no start that yet.
I have four 4tb drives set as mirrored vdevs (8tb usable), and the system boots from a mirrored two usb DOM (disk on module) that plug directly into the mainboard. Not sure of the DOM size, maybe 32gb, and 64gb ram. System has been rock solid for a couple years.
Abruptly, a few days ago I could no longer get to the UI/login screen and the browser just sits and spins. I figured I could just pop into the cli via ssh, and it checks my credentials correctly but instead of giving me a shell, it just prints out the following:
Last login: Sat Oct 29 22:36:53 2022 from 172.30.30.177
FreeBSD 12.2-RELEASE-p14 325282c09a5(HEAD) TRUENAS
TrueNAS (c) 2009-2022, iXsystems, Inc.
All rights reserved.
TrueNAS code is released under the modified BSD license with some
files copyrighted by (c) iXsystems, Inc.
For more information, documentation, help or support, go here:
http://truenas.com
Welcome to TrueNAS
File "/usr/local/sbin/hactl", line 171, in <module>
main(args.command, args.q)
File "/usr/local/sbin/hactl", line 17, in main
client = Client()
File "/usr/local/lib/python3.9/site-packages/middlewared/client/client.py", line 283, in __init__
^C^C^C^C
The ctrl-C's are my attempt to stop whatever is running and give me a shell prompt, but I never get anything else in the ssh session. I run the system headless, but will try to get a monitor/keyboard/mouse on it today to see if I can access the console. I'm worried that if I just reboot it, it may not come back up and at this point i have no way to get the system config off it or anything. I have popped into each jail and vm, as well as copied a few files on and off the shares, and everything virtualized has no visible errors or issues in their logs. It just seems to be the UI and ssh that are hosed.
Could someone perhaps point me into a direction to troubleshoot? Any pointers or advice is most appreciated!
J
http://truenas.com
Welcome to TrueNAS
client = Client()
^C^C^C^C
J
